I used the original Accucraft glad hand. I drilled a tiny hole in it and glued a tiny nail in the hole. Trimmed the back side. Then I put a drop of glue on the nail head and let the magnet take hold. I did this to every glad hand. I tried using just one magnet and it twisted too easily, so I added a magnet to every glad-hand. The hose is flexible surgical tubing. I’m still fine tuning the hose length. It’s different on some cars. Next I’m going to drill a tiny hole in the KD and add a tiny cotter key to use to fasten the lift bar chain. I may add some nylon thread under the coupler to hold the hose up off the track when it is uncoupled. You can uncouple with a long screwdriver and the hose pops off just like a real one. It doesn’t have a blast of air releasing, tho.
It looks a lot better than that metal “air hose” that hangs under a KD.
