Well the weekend is over and I still don’t have the roof on yet. With a week to go I decided that for once in all these builds, that I would have some time to pull a Dunakin, and get some details added. Putting the Tin up would just get in the way of handling and working, so I have made a list of some details to do, and when done, Then the roof.
I asked WWRD ( What Would Ray Do )? All the Tower photos that I studied all showed the Switch Levers in the room, SO I needed a set, so that if someone actually looked in the windows, There would be levers. Started to cut some wood. I don’t need no stinking plans, just wing it!
The base, levers and dividers.
Lay them all out, space, Glue. Easy Breezy.
See I knew that it would work.
Add some handles, carve down to look liked machined parts.
Add paint to make them look pretty. Actually the zones in the yard were color coded to help keep thing confused.
A building needs heat, heat requires a furnace, furnace requires smoke stack. So made me up one, Two story none the less.
The bottom floor.
The top floor.
And the whole thing on the back side.
Gotta Have power too. It comes in at the weather head.
Goes thru the meter and into the main switch.
And the whole elect connection, top to bottom.
Thats all folks… Still have to make a base, as for more details, Rain gutters and down spouts. Signage. Lights. ( I hoping that Todd shows how he uses solar to light things up). Front steps, and maybe a hanging light over the door.
