Today we make the mold. The RTV ( Room Temperature Vulcanizing) Silicone I use is a Professional product from AeroMarine. This stuff is a two part system. The Silicone ( the rubber stuff), and the Catalyst ( think of it as the hardener). The ratio for this product is 10:1, Silicone to Catalyst by WEIGHT. To properly mix to the right ratio you MUST have a Scale that weighs in Grams. Other manufactures have products that have a mix ratio by volume, 1:1 or 2:1 etc., and you don’t need a scale just measuring cups. We will weigh out what we need.
To get an accurate weight of the silicone, we place the plastic mixing container, with the mark of how much we need ( rice measurement ), on the scale and then zero out the scale with the mixing container on the scale.
Now we add the Silicone to the mix container, up to the line we drew from the rice level, and note the weight in grams of 176.
We now repeat the process for the Catalyst, after vigorously shaking the bottle for 1 minute. We add 17 grams to the plastic cup.
To aid in the release of the mold from the box, I now coat with mold release agent. A little goes a long way. You want a light coat, never a runny puddle.
Add the Catalyst to the Silicone, and mix together until you get a uniform color mix, no streaks. This Silicone has a “Pot Life” ( the amount of time that you have to work with it before it sets up to be to hard to be useful ) of 45 minutes, Plenty of time to get in the mold box properly. You want to be sure and stir together well, scraping the sides and the bottom as you mix. Now here is the clinker… Try not to stir in any air bubbles, or as few as practical.
Now is the time if you have a vacuum chamber to de-gas the mix, I sometime do, but mostly I don’t. BUT, I do let it set, and I bang the mix cup on the floor and work bench to assist with getting the air bubbles to the top. Not a really big deal because with this products 45 minute Pot Life the air rises to the top, and the top is away from the master part. You don’t want air bubbles trapped against your master.
Now we fill the mold box. There is a right way and a wrong way to fill the box.
WRONG WAY: Just dump it in on top of the master. Most likely lots of trapped air.
RIGHT WAY: You need to start the fill in the lowest part of the mold, away from the master, and then have the mix FLOW over the master. To help brake up any air bubbles in the mix, as you pour, slow down the rate, and rise the container up and away from the box, so that you have a small continuous narrow stream hitting the pile in the box. The stretching of the stream tends to brake up the bubbles on the way down.
Thats the hardest part. Now full, shake, jiggle, bang, tap, the mold box to assist the air bubbles to rise to the top. Set aside for a minute and tap and bang, drop, juggle again, and again, and again, until you feel confidant that none of the air bubbles are against the master. You will continual to see little air bubbles rise to the top. At the top is OK, on the master is not.
Now sit back and wait, 16-24 hours at room temp. Don’t try heating to get it to set faster, As it will change the consistency of the Silicone, Just go on to something else and get back to it tomorrow.
Tomorrow we de-mold and cast.
