I learned a few things last weekend and yesterday, starting with raw output force of different drives.
By “servo drive,” I mean the thing I’ve been messing with.
Piko (similar to LGB, but I don’t have an LGB): 0.22 lbs causes spring to flip; motor put out 0.40 lbs
Aristocraft: 0.20 lbs
Train-Li: 1.02
Servo drive (resistance when auto-endpoint-setting kicks in): .43 lbs (@ crank radius of .47")
Servo drive (stall force): 4.80 lbs (@ crank radius of .47")
This heavy-duty servo puts out a lot of force, more than the other components (e.g., the servo mount) would want to see.
The automatic calibration of the board, however, was causing me problems. I set up several wire & tube configurations last week, and all but the most simple had more mechanical resistance WHILE THROWING than the board’s resistance threshold. So, while going through the calibration routine, the controller would see this resistance, and assume an endpoint was reached.
This is exacerbated with increased complexity of the cable path. I found that additional length and curvature, especially reversing curves, really drove cable resistance up. At ten feet, with reversing 3-bend, the wire-in-tube simply locked up, and spray teflon lube didn’t help.
Additionally (and this is a little hard to describe), a small resistance at the throwbar (say, sticky points) caused a sort of traffic jam back along the cable path, as the cable went from one tube wall to the other.
Point being, there are a number of variables in the tube / cable, so simpler the better.
Having said all that, I received some good news this morning from Duncan McCree, designer of the controller board. Here’s the jist of the Q&A:
CJ: Can I manually set the ends of travel beyond what the automatic method thinks they should be? The unaided auto method feels the resistance in the tube, and stops too soon. But if I help the servo with my finger, the positions end up ok, and the servo still stops properly.
DM: Yes this is a perfectly good way to set the end points - wait until the servo arm gets where you want and then push back to get it to accept that position.
CJ: Even if the servo does stop where I want it, does the above sound damaging in some way?
DM: No it won’t cause any harm.
CJ: Is there a way to increase the auto resistance amount?
DM: Every time it runs it ups the resistance level a bit - so if it stops too soon try it a again. [edit: Greg, it’s funny that Duncan didn’t mention CV50, but maybe he was assuming I’d want to stay more operationally generic]
CJ: I’d like to try manual setting with the pushbuttons, but I couldn’t work out the instructions. Line 1 of your chart says: “Hold Button | LED1 flashing | Set the endpoint for Button 1.” Which button? Do I force the servo into position before this, or after, or ?
DM: You hold down one of the buttons until the LEDs flash. Then you use the 2 buttons to move the servo arm to the correct position. You don’t move the arm before you start.
There are a number of additional things to resolve in this project, like final mount design & final cable / wire selection & attachment method. Also, I’m coming back to the idea that track-side spring is needed.
Thanks for viewing!
Cliff
