So, Cliff was very generous and sent me his first test print (the one on the bottom above). Friday I spent the evening carefully removing the supports. Holy moly, that is a crazy amount of work! Yesterday I repaired what I broke removing supports. I had snapped both main rods, broke off the light in the cab, shattered the roof, and more.
The roof was covered with a thin ABS sheet glued to what was left of the old roof between the rails. The rods were pieced back together and the cab (reverse) lamp put back in place as well as a few other things tacked back where they belonged. I did not attempt to repair the control handles I broke off. No one but Cliff would notice them missing.
Here is are pics of the current status…
My plan is for this to become a flat car load on a short stub of 2’ track. Not sure if I want to paint it as if it was ready for display at a museum, or rust it completely as if it were just rescued after sitting for what, 100 years?
I’m leaning toward the rusty look, although that will be a lot more work. I would use the Modern Masters Iron Paint and Oxidizer that I still have left from a sign job years ago. In either case, a base coat of flat black everywhere is probably in order.
Too cold and windy to paint here, so I’ll take it to work where I have a ‘paint room’ on Monday.
