This was started several years ago and had a request to do 4 more frames for a friend, so I’m back to finish them up. The drivers are the right size and by adding .680" between the 2nd and 3rd drivers, the axle spacing will be correct also. I start by milling the frame for the splice pieces. (no photos) Frame is cut with a band saw
Frame is setup in a fixture to keep it square while attaching the main connector
The frame rails splice connectors are bolted in
