Three years ago I was gifted a large old wooden Engine House probably 1:24 scale. It was in tough shape then, but I replaced some missing boards and a rotten door frame while up scaling it to work with 1:20.3 equipment. This was taken before installation in June 2014…
Summer 2014’s project was to build the concrete foundation and track to use it as an industry. It has been outdoors ever since occasionally getting hosed off or cleaned with a leaf blower. I lifted it from it’s foundation last weekend to do some minor repair and install lights. Tonight, when attempting to glue back that new lower piece of Cedar shown in the above pic I noticed that the extent of structural rot along the sill plate will probably result in a collapse before Spring.
Here it is soon after being placed on a brand new foundation in June 2014…
Behind each one of the horizontal siding members is a .75"x.5" timber, one of which is the rotting sill plate. Behind the bottom trim piece the siding is also rotting. The sill plate and siding at the bottom is all that holds the structure up. The frame timbers and siding above the sill plate are in good condition. My thinking is that if I can move the support away from the sill plate on to one or more of the sound timbers, the bottom can rot to dust and the building will still stand. My plan is to cut a single piece of .25" clear plexi the size of the entire interior wall, then bolt it along the sound horizontal members. The bottom end of the plexi would then be the building support.
What I am wondering is how goofy it will look with glazing .5" deeper that the window trim. A smaller piece of plexi could be cut t fit flush to the wood window trim where you would expect the glazing to be. If I do that I will probably include some painted hardware cloth to stand-in as mullions. It would be possible to support the bottom with a smaller piece as well, but then it would only bolt to one of the stable horizontals. I kind of like the idea of bolting to two which would also reinforce the entire side holding it in square.
Thoughts?
