With the release of the Spektrum DX5e Radio offering 2.4 GHz Spread Spectrum performance for under $100, it’s time to upgrade the radio system in my live steam Shay. I originally installed a Futaba AM radio and have not been happy with the resolution or the glitching on the cheap radio system.
The DX5e was designed for aircraft use, but from what I can find on the web, the 2.4 GHz band is used by either surface or aircraft. The one thing I’m not sure of is how the throttle stick works having never flown R/C aircraft. For the Futaba radio I installed an optional Ratchet Clip on the throttle stick so that it would not spring return to center, but rather stay where it was set. I’m assuming that aircraft radios come with the throttle stick already set up that way, but I can’t find any info on-line.
So - someone who flies R/C planes - Can you tell me if the throttle needs to be held open (like an R/C Car) or does the stick stay where you put it? How about the other 3 control surface sticks?
For now I am only using the throttle stick to control the Johnson Bar. This gives me both speed and directional control on one stick. In the future I may want to add a servo for the throttle. When I do that I’ll want two sticks that stay where I put them.
