2nd test under steam (indoors) was 100% successful. I managed to get the servo horn positioned properly so stick center is neutral. With the corrected bind procedure I was also able to get the fail-safe properly programmed to go to neutral. I tested the fail-safe by setting the engine into motion going forward (within easy reach) then powered off he transmitter. The loco immediately went into neutral and stopped dead. Perfect
Range doesn’t seem like it will be any issue at all with the antenna just poking out of the wood load.
Control is more than adequate. Good enough for switching
With the throttle open 1/3 turn I can go from dead stop, to crawl, to moving right along in fairly smooth steps.
A very happy camper I am.
Rain is supposed to stop overnight with a dry and mild day tomorrow. Assuming I can get the rest of the line plowed I’m planning a steam extra for late on Christmas day.
