i am hoping that someone can help provide info needed to get my locos back up and running. I have 3 Bachmann Spectrum Fn3 2-8-0’s that all have the same issue. All three has one of the two tear idler gears broken. its the one that has the small gear on top of the large gear.
The small gear part has broken apart from the large part. has anyone had this same issue. it seems that bachmann has an ongoing issue with gears. The last engine that developed this issue was used to pull only 2 Accucraft passenger cars so it didnt pull too heavy of loads. The other two only pulled a max of 8 accucraft and Spectrum freight cars. These are just idler gears so they should not have a lot of stress on them. Has anyone replaced these gears with brass ones and if so, where did you get them. i has been looking for replacements other than the almost impossible to get replacement gears from Bachmann.
i have even considered replacing the whole gearbox assembly with the C-19 gearbox and motor assembly.
Dan Stuettgen
Colorado & Rio Grande Southern
