Rockwall Canyon Jeff said:
Hi Stacy,
Thanks for the compliment on the live steam shay. The answer about steam vs diesel is…no. In general, live steam model will rarely ever win in the traction or power race with electrics. The primary reason for live steam losing in traction is oily rails. The shay has the benefit of having only traction wheels, and having them in sort of a power truck arrangement which helps adhesion. Regarding power…most live steam engines have twin double acting cylinders that drive the wheels directly through the wheel cranks. At a certain grade, most traditional live steam engines will stall out. The shay has 3 double acting cylinders and a gear reduction to amplify the pulling power by allowing the engine to run a higher rpm.
To put it in perspective, the same log train pictured, could also be pulled by my S-4 switcher. My GP9 with added battery weight and factory tractionntires, could pull 7 or 8 four axle freight cars up the grade.
Fascinating stuff here.
It seems that in scale, the trains can do what their big cousins cannot do. At least that is what I am gathering.
I know diesels pretty well. UP’s Centennial locomotive remains the most powerful diesel locomotive ever created in this country. With 3,300 X 2 diesel engines, she could pull her weight and the weight of a heavy coal consist over mountain ranges out west that defy the laws of physics.
In scale though, it is interesting to see what these locomotives are capable of doing.
