Now we’re going to build the front door. We’ll need a piece of 1/16" styrene cut 2 1/4 x 7/8" and a .02" piece cut 2 1/8 x 3/4".
NOTE - If you are building an older gp38/40/SD40 wide cab, you need to reduce the widths to 3/4" and 5/8". The door is the same, but is 1/8" narrower.
Center the .02" piece on the back of the door.
Sand the edges of your door to a slight curve, and then mark it up as shown below for hinges and a door handle.
Cut four pieces of .06 x .125" styrene 1/16" long. Glue these on the side of the door as shown below. They do not quite come up to the top of the door. With your door on a flat surface as shown, make sure these pieces extend past the door so that they sit against your flat surface. The .02" piece on the rear of the door lifts it a bit, so make sure these pieces extend right to the flat surface.
Cut four pieces of .02 x .06" styrene 1/8". These go on top of the door as shown below, flush with the outer edge of the door.
Cut a piece of .02" styrene 1/16 x 1/16" and mount it as shown by the blue arrow. Cut four pieces of .025" rod 1/8" long and mount them as shown by the green arrow. Keep them to the outside of the edge of the door. Now cut some bolt heads from .04" hex and mount them as shown by the red arrows.
Now for a door handle, I start with a 1/16 x 1/16 x 1/4" piece of styrene. Cut out the green sections as shown below. Sand it to smooth it out and taper it a little, and then mount it on your door. I kept a thin piece of styrene under the inner edge while drying to keep it away from the door.
Now the door will be mounted 1/4" to the right of the center of the nose, and 3/16" up from the base.
NOTE - On the older GP38/40/SD40 units, cut a piece of 1/16" u channel 7/8" long, and mount it centered just above the door as a drip trim. It will extend slightly over the headlight. This trim was not used on the SD60f.
