I started this a week ago. It is being built for a friend of mine that I met at the National Garden Railroad Convention in Cincinattti, Ohio. It is built from cedar, pinned and glued with Tite Bond III.
To start with I needed a way to cut board and batten siding. So I have a molding dado set. I didn’t have the correct knife set so I used this set of knives for the cuts, I only needed a 1/8 inch depth cut so it worked out ok. Inn the future I will try to find a 3/8 wide Sears Craftsman set for this…
Up next is the board that I cut…
