So I’ve been busy spraying and sanding my snow dozer with a can of Rust-oleum primer for the past month. But the last two nights worth of priming have resulted in a very different finish on the model. Instead of a nice rough surface that sands smooth, the primer dries to a smooth semi-gloss, that when you sand it, just clogs the heck out of 220 grit sandpaper. The primer doesn’t act as if the can is empty, but I’m wondering if less primer is getting sprayed out and more propellant is coming out as the can empties.
Has anyone else had this problem?
