On the Durango & Jasper we have a gold mine. It is inspired by this 1980’s HO layout by John Olsen:
So far we have the 2 level trestle roughly in place. Here’s a shot after the initial install of lighting within the mine entrance:
It seems like this mine needs a lot of details. I’m starting by adding a rock building to store dynamite, to be placed at the far left side of the above photo on a rock ledge. There will be wooden steps leading up to it from the upper trestle level. The building will be a simple rectangle with a single pitched roof of corrugated metal. It will be ostensibly built of rock (the same rock as the rest of the landscape) with a metal door.
I’m planning to build it using a technique of Ray Dunakin’s (I try to steal from the best), as in his 2 story house (link).
Ray built a form, put rock in the form, and mortar inside that. After removing the form, you end up with a building (there are more steps :-)).
So here’s my form (made out of foam board):
Here’s a wood door frame where the metal door will be. It will be mortared into the form and held in by rocks and mortar:
Some more bits of foam core were glued in place to hold the wood frame in the right spot so I can add the rocks around it:
And with the wood door frame in:
Next up is adding rocks and 1/4" hardware cloth for added strength in the mortar (as per Ray). Then mortar on the first wall, let it cure, turn 90 degrees and do a similar thing on the next wall and repeat.
I’ve never done this before so wish me luck! All my mistakes will end up here
Cheers!
