Hi all I’ve been busy beavering away at another kitbash, this time a RGS T-19 4-6-0 out of an Annie, following Rod Hayward’s notes on his bash (see www.gtrains.co.uk). The loco started off as one of the North Pole and Southern Annies, with Stephenson link valve gear aka:
It had it’s nose cut off, and the smokebox shortened by about 3/8", a new smokebox door, new scratchbuilt cab, new running boards, and a bigger tender (taller). This is what it look like after the initial work was done:
Following that, I’ve spent a fair bit of time detailing it up and doing all the plumbing, and giving it an initial coat of primer and gloss black so I can see the imperfections:
Apologies for the messy bench and other unfinished projects. I promise it was clean when I started this loco! Well I finally got it all together last week, and yesterday gave it its first run using RCS and batteries. I’ve uploaded a video on YouTube here http://www.youtube.com/watch?v=h_EoCFx1kjU which also shows my garden railroad. Still has a couple of things to finish off, like detailing the cab roof and a little bit of plumbing and new steps for the tender, but she is nearly done and runs a treat. I must sincerely thank Rod for both his article and his guidance along the way, it has been invaluable. Further pics will be posted once she has been through the paint shop. Cheers Tony
