My wye doesn’t require that any switches be toggled. The tail section is controlled by the LGB EPL attached to the turnout. The two lead in turnouts also throw the wye turnout into the proper position. Everything operates automatically.
When you want to use the wye, you toggle the appropriate turnout on the mainline and this also throws the wye turnout to that direction setting the polarity on the tail section. When you throw the mainline turnout back to the mainline, the wye turnout remains as it is (foolproof).
You pull your train into the wye and there is diode protection at the end, so the train stops automatically before departing the end of the track (foolproof).
To leave the wye in the other direction, simply toggle the other turnout on the mainline to the wye. This simultaneusly throws the wye turnout and the polarity reverses. The engine now gets current though the diode and the train proceeds out the other direction onto the mainline (foolproof).
You can toggle the wye turnout and reverse the current to the tail section independant of the two mainline turnouts (i.e., toggling the wye turnout has no effect on them). This way you can work within the wye (toggle trains back and forth to “interior” sidings) without effecting the mainline.
Once the train is back on the mainline, throw the mainline turnout back to the mainline (wye turnout ignores this) and reverse the power to your train to a forward direction on the mainline.
