I have been working on the old mountain pass, reducing the grade, putting in a new tunnel and increasing the track curves from a tight 4’ diameter to a better 5’.
I have been trying different track arrangements to get the most bang for the buck and I’m looking into a reverse loop.
The hitch is I also want this to be a continuous circuit to the main with the option of reversing a trains direction by taking another switch to head back the way it came.
I have limited funds and I want to keep this simple. I have a WYE and a turntable that uses DPDT switches to change the polarity. Engine goes on, stops I flip the switch and off it goes. Can I do the same thing with a reverse loop? A train enters the loop and instead of continuing on the main I decide to send it back the way it came. the engine enters a section of isolated track, stops I flip the DPDT switch train moves off in the correct direction.
Could it be that simple or should I look into getting a LGB reverse loop automatic setup? This of course is track powered and outdoors.
Thanks.
