Thanks, Joe, and yes, all of the work was done by me. Except for the covered bridge, I did it all. People ask me how I did it and I respond just one block or board or shovel full, or one rail at a time. Looking back at some of the early pictures it amazes me how much I was able to accomplish but a lot can be done if you keep at it. It really helps to break down big projects many smaller tasks. That way, when you complete a particular task you can look at and feel a sense of accomplishment, and then set out for the next task. At the end of the day you realize that you got a lot done.
back to the pics:
14 phase two: View from deck of house. Can see track at grade level on right, block wall elevations on left side, and treacle platform 9 1/2’ from ground in the back left corner.
15 phase two: track supports and track in place for yard (over underpass).
16 phase two: McKee’s Rocks, a good vantage point for viewing both ends of phase two.
17 phase two: end of platform, track 9 1/2’ above ground at far left end.
18 phase two: more chicken wire for burlap mache rock work. Will allow light weight concrete rock work on the wooden framework.
19 phase one: lower track is the connector from phase one to phase two.
20 phase one: cedar tressel.
21 phase one: cedar and brass bridge.
22 phase two: construction of tunnels under McKee’s Rocks.
23 phase two: track being installed on part of elevated block wall section. The proposed track roadbed was laid out with two runs of 1/2" pvc conduit pipe. The supports consist of 1" pvc pipe upright pounded into the ground 18" (used a pole pounder and 1" iron pipe to make hole in ground and then inserted 1" pvc pipe.) along the proposed track roadbed. The supports were spaced every 12". A 1/2" pvc cross, glued to a piece on 1/2" pipe was loosely set into the 1" pipe sticking out of the ground. After a number of supports were set in place then the two runs of 1/2" pvc conduit were screwed to the top edges of the crosses to make the mounting surface for the track. Then the crosses were raised above the 1" supports to the desired elevation and then screwed in place. This makes a very strong ladder-like roadbed. The elevations of each support are easily adjusted by loosening the screw, raising or lowering the roadbed, and then re-installing the screw.
24 phase two: platform end framework.
25 phase two: platform deck installation, cantelevered over fill area below.
26 phase two: platform deck steps to ground.
27 phase two: platform bents being installed.
28 phase two: excavation begins for underpass construction.
29 phase two: completed hole for underpass.,
30 phase two: underpass construction using railroad ties.
31 phase two: underpass complete. View looking at underside of platform.
32 phase two: view of phase two from shed (modeled after Pola Silverton Station).
33 phase two: platform almost completed.
34 phase two: covering platform. First layer expanded galvanized metal, then 1/2" plastic hardware cloth, then landscaping fabric, and on top is fiberglass window screen.This has proved to be very strong but still allows water to drain through.
35 phase two: McKee’s Rocks vantage point.
