My friend stopped by today and we hooked up my foney to RC. What a difference it makes. We were able to hide the servo inside the coal bunker leaving only the arm sticking out. It was placed in line with the gas lever. We then took some wire and bent to fit in the slots of the servo and the throttle. The servo runs to a wire harness. Then off the harness we have a plug so we can charge battery without taking out of the bunker. I plan on cutting a hole ontop of bunker so I can put the switch and charger plug ontop. Then I will add a removable coal load to hide the switch. The battery is a 4.8 volt 500MA Nicad battery. I also got another servo that will also be placed inside bunker with a hole to fit wire through. That will go to the forward/reverse lever.
Overall view of forney with rc
the other side
close up of inside on gas lever side
servo
setup from throttle side
Wire harness setup. This will all placed inside bunker.
