Every spring I re-level the railroad and adjust for grade. And every year I start at the north abutment to Resignation bridge, that is my reference point. Last year the crews were complaining about having a grade coming out of the lower reverse loop (Fairhaven), a grade that was never there before, and a grade that was so steep that some locomotives were stalling out on it. So this spring I took a look at the north abutment of Resignation Bridge. It seams, that over the years, that abutment has been slowly lifting out of the ground. Originally the bridge barely cleared Prostitution Rock, but now there is a good amount of clearance between the bridge and the rock. This also explains why I keep having to raise the other bridge (Saw Mill Run Bridge) every spring. So this spring, I am lowering my railroad back to the original height.
The track has come up a good 2 inches (4 scale feet) over the years. This also explains why some feeder wires have broken, they were stretched each year by the rising track. So I am lowering the track (as seen in the photo) and repairing broken feeders. I may have to explain to the board of directors why the railroad didn’t open on time (May first) this year. I hope I don’t have to. That Dave guy can be a real bear when he doesn’t get what he wants.
