This past weekend I decided it was time to bite the bullet and get the trestle raised. First step was to replace the missing boards, so the thing would act like one solid unit.
And of course clearing out the debris and underbrush was part of the job. Them darn weeds grow like…they grow fast.
Then I freed the trestle from its cement pad. Some of the piles had stuck to the pad, probably because I set the trestle while the pad was still soft. Then I raised the trestle, trying to cause as little damage as possible, and I slid 12 inch square pavers under the trestle. The pavers were thick enough to bring the trestle up darn close to the level I want it at. Again, my goal is to get the lower reverse loop as close to dead flat as possible.
Some of the piles had rotted on the ends, and some didn’t. So, for the ones that didn’t sit on the pavers, for whatever reason, I put pieces of broken slate under them until they were supported. The bent on the end I sacrificed, the rock next to it had shifted, putting stress on that bent and deforming it.
Then I buried the paves in ballast. I had put broken shale under the trestle before, but I didn’t think I had enough of it to completely cover the pavers. Its not quite the look I was going for, but it will work.
Now I just have to build 2 short, deck tress bridges to properly carry the track from the trestle to grade.
While I was doing repairs, I also replaced a missing board on my Warren (not Howe) bridge.
