Hi Guys,
I’ve been pretty busy building 3 more SD60f’s using the build instructions I shared. I was using the build article, but it did not survive the transition to the new site. I’ve tried to edit it, but it appears to be over the size limit. I think I might rebuild the instructions as a web page so that I can divide the instructions into chapters to make it easier to find what you need.
So I am now using the original build thread which contains the same info.
I’ve done a redesign of the tail which I’ll share. I’ve set it up so that a speaker box with a 3" speaker can slide in from the front, and is secured from below with screws. I also drilled a 2" hole at the rear to make it easier to get at the rear door window and headlight.
Shane
