I split redwood to make shake shingles
2019-06-07 13.08.56 by Dennis Rayon, on Flickr
Completed Structure
2019-06-08 22.23.54 by Dennis Rayon, on Flickr
Completed Structure
2019-06-08 22.23.23 by Dennis Rayon, on Flickr
2019-06-08 22.23.03 by Dennis Rayon, on Flickr
IMG_4038 by Dennis Rayon, on Flickr
The Completed Log Structure
Looks like the real thing. Chinking makes the whole thing work. The resident needs to do a little yard work there at the front door (https://largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-wink.gif)Thanks for sharing.
Dennis, I’m always amazed with your continual discovery of new techniques and how excellent your work is.
This is outstanding! Again!! Bravo!!!
Really well done, yet again, Dennis! Bravo! I agree with Cliff about your amazing ability to invent new techniques that the rest of us can learn from.
Thanks Dan, Cliff and Jim for your kind compliments. I thrive off creating something different, that works for this hobby
Working On Another
This time a small hotel and bath house
Untitled by Dennis Rayon, on Flickr
The left side wall, had to paint this wall first before assembly. I use the laser to layout the words or lettering, It is so much easier to paint the walls after the laser has laid out and outlined the words.
You still have to hand paint the words, after the laser outlines it, it gives a narrow cut line to separate the paint lines.
Just plain old “Hotel”??? No terribly alliterative name? “Hestor’s Hospitable Hotel”? “Hugo’s Handy Hostelry”?
Looking good so far…
Aw man, he’s doin’ it again!!
This picture shows the bath house headquarters , and the boardwalk in the front
The front boardwalk is Magic Sculpt covered with Redwood planks
Dennis
Dennis,
I missed this thread, and I am sorry for it! Please allow me to echo the others’ compliments on your work and gratitude for sharing it. I had to look up “precision board,” to be honest. You are right, though, it isn’t cheap, even if you get it locally! Assuming I had that combination of project, time, and funds, is it something you can work with a Dremel style tool?
Thanks,
Eric Mueller said:
Dennis,
Thanks,
Thanks Eric
I prefer a flex shaft grinder, a little more comfortable and smaller diameter, making it easier to operate.
I prefer it because I can operate it with the foot control.
https://www.grizzly.com/products/Grizzly-Flex-Shaft-Grinder/G9928
Also taking cheap kitchen butter knife, I sand down to a desired width, not sharp like a chisel, allows to make Brick verticle joints,
Stone walls would be easier than brick with a dremel. Verticle siding is easy by hand, a dado blade on a table saw can make
lap siding and board and batt siding. It is soft enough to accomplish a lot of detail by hand.
A Fun Product
Dennis
Dennis,
Thanks again! I just replaced my Dremel, but I will have to take a look at this device in the future. One follow up question about the material. Is it easily cut to useful sizes with my little saber saw? Or would I need a real table saw of some sort? I hate to keep pestering you, but as I go from “get something running” to “build something to give those trains a reason to run,” I have been tinkering with materials that match my skills, climate, and available storage space!
Your questions are no bother, any wood tools works great, always use fine tooth blades. I buy mine in 2ft
x 5ft sheets, I have pretty well have almost all major tools because it is my business, I still cut the sheet down to smaller
size by cutting with a sharp utility knife.
any fine tooth blade on a saber saw would work good. I use a small hand block plane to smooth
down and trim minimal amounts off.
A small Japanese type hand saw is a great tool. Cuts on the pull stoke.
They are pretty slick and not well known!
I got the Brick painted, i prefer the mixed color brick
