[b] This is the third part of the POC’s turntable post. I thought about bumping the first two parts up to get everything together but decided that it’s wouldn’t be comely to bounce my own posts up over newer posts so the links are here for those that may want to refresh their memory. http://www.largescalecentral.com/LSCForums/viewtopic.php?id=13654 http://www.largescalecentral.com/LSCForums/viewtopic.php?id=13655 ****************************************************************************************
The mechanism is quite simple and resembles prototype installations I’ve seen. The redwood planking was cut to size to perfectly accommodate the brass strip between the rails and provide flangeways and is 1/8" thick. I plan additional planking later but what you see is all that’s essential for this part of the project.
This view shows the latch in the open position.
The bottom strip is just a 3/4" x 4" piece of sheet brass. You can buy this size in many hobby shops, some hardware stores and from Micro-Mark. I made the latch itself from the same size brass but the next size up in thickness for additional rigidity. The travel is approx. 1-1/2".
The latch here is in the closed position and locks the turntable in good alignment. The fit is fairly tight but a little slop is okay and even desirable as long as the rails align okay. It needs some clearance to move easily.
The only moving part aside from the turntable itself is the latch. As mentioned it is 3/4" x 4" brass strip. A piece of square brass tubing was soldered on top to give something to push against to move the latch and then painted. Be sure the handle doesn’t stick up above the rail head and you’ll have no clearance problems. I kept it removable to allow cleaning underneath and also to allow for lubricant should it be needed later. I’m not lubing mine unless it becomes necessary. While I was at it I added a simple backstop for the turntable end that ended in midair to avoid the potential for “little” tragedies.
The posts are 3/8" cedar dowel inserted into 23/64" holes. No glue. That pretty much completes the POC’s turntable at Port Orford. Yet to be done is the fueling rack which will be serviced directly by Bunker C tank cars and lots of additional planking. This will provide the equivalent of another industry (tank cars) as well as a place to fuel the engines.[/b]
