Clean the saddle of the queenpost out with a drill bit. One a little larger than the truss rod. Glue and pin the queenposts in place. Locate the turnbuckles and clean them out with a pin vise. File the slot a little also. You’ll see why in the last step. I wish PNG would supply longer truss rods. (I am going to find a source for my own.) Push the turnbuckle on. Center the truss rods on the turnbuckles and put a drop of glue to hold them. Let dry. Don’t glue the turnbuckle.
(http://freightsheds.largescalecentral.com/users/jebouck/MOW17rs.jpg)
I bend the rods down just in front of the notches and hold them in place with a block. PNG’s instructions say to poke them thru the floor. Doesn’t work to good with flat cars, etc. You can see here that if the truss rods were longer, you could push them under the bolster as well.
(http://freightsheds.largescalecentral.com/users/jebouck/MOW18rs.jpg)
Locate the turnbuckle boards. Now you know why you cleaned the turnbuckles up. You still have to sand the boards a little so they will fit. Push them thru the turnbuckles. Now apply a drop of glue to hold the turnbuckle in place.
(http://freightsheds.largescalecentral.com/users/jebouck/MOW19rs.jpg)
As far as I’m concerned, the bottom is done, boys! “That’s it for today”
