So off and on we have this discussion and I am wanting to consolidate some of my thoughts and assumptions before spending a lot of money.
Craig has me turned onto buying full sheets of Styrene. And this is fine and dandy for most things. And very well maybe what I stick with. I am using .125 thick materiel for the challenge and it is working better than I expected. However I still want to explore some other things. In y googling and from what others have mentioned here there seems to be some options.
Plain Styrene
Sintra
Gatorfoam
Gatorplast.
I like styrene. I am familiar with it, have bunches of it, and it is easy to work with and weld with MEK. So sticking with pure sheets of styrene at this point is preferable. My only issue at this point is that even at .125 its thin I worry about the longevity of the seems (even being welded) holding up. Smaller buildings this will not likely be an issue. But I still thinking a foam core and a thicker materiel wouldbe better in the long run for larger buildings that will have to remain out in the elements (covered when not in use). This brings me to the commercially available foam cored stuff.
Jon recommended Gatorfoam. and I can get it by the sheet. However after doing a bit of looking the gator foam product is a styrene foam core but a plasticized wood fiber paper for the outer surfaces. Not sure I like that. The other product made by the same company is Gatorplast which would honestly be perfect. It is a styrene core with high impact styrene faces. I would immediately jump all over this except my local supplier doesnāt carry it (need to check others). The beauty of this stuff is since the faces are styrene, then other pieces of styrene can be welded to it with MEK and MEK can be used to join the foam board as well.
The final one is Sintra. I know a lot of people love this stuff. And I can buy it by the sheet. It is a PVC product. Now my question with this would be the ability to attach styrene to it. Bob did say you can use PVC cement and it will weld styrene to PVC. Now I have just tried my first experiment witht he challenge and so far it appears that the Styrene and the PVC have indeed melted together and not just merely stuck together. If PVC cement is actually melting the styrene and welding the two plastics together then I think I would be just as fine with the Sintra.
Any thoughts here guys? With the number and sizes of the buildings I would like to create over time I just think a thicker (1/2") or so product would ultimately be best. And while using pink foam board is also an option its limited in what can be stuck to it.
