Any of your tack adhesives will bond the two different materials quite well. Weld on 16 is a great choice as is e6000 and the 3m that I personally prefer. Also note on the PVC boards there is a UV treated and a plain. Also note that some comes {masked} or covered with a thin layer of film on one side that MUST be removed before gluing. The Komatex brand name tends to be a bit cheaper than the Sintra brand name if you can get it out there.
Quick story on glue. I had a toilet that would slowly leak (run), after several flappers and a lot of frustration I found the problem, a crack at the bottom of the overflow pipe. Not wanting to remove the tank or replace the toilet I drained the tank and cleanly snapped off the overflow pipe as I had nothing to lose. I applied my favorite 3m plastic and emblem adhesive and pushed it back together. Waited about 2 hours,refilled the toilet and no more leak. That was 2yrs ago but perhaps I shouldn’t have cursed myself or perhaps I should contact 3m and let them know…
Yep.
AHA! The trick to posting a one word reply is to quote the post!!! Nice work Cliff. Hope your surgery goes well. My wife had that done and 10 years later the entire shoulder replaced.
sounds like a 3m customer testimonial to me!
