Okay, what happened on posting pictures?
Can’t post them anymore…
(http://i18.photobucket.com/albums/b107/139vinny/Trains/0881b1c2-48c9-49b7-bfb3-afee87a0d4a7_zps7a5f077f.jpg)?t=1366042871
Figured it out, was getting my forums confused!
(http://i18.photobucket.com/albums/b107/139vinny/9effdb07-b0f7-4502-82f6-e7c3540c3774_zps8bace5da.jpg)
Joe Zullo said:
[youtube]http://www.youtube.com/watch?v=rPvrJlsgP-A[/youtube]
I tried the tags, but can’t get it to post…
Where are you copying the link from? I think that’s my problem
I copied the URL from youtube.
Under the video, there’s a “Share” tag, if you click on that it’ll give you a shorter version of the URL…just “Copy” and "Paste " that URL between the tags…
[ youtube] XXXX [ /youtube]
I have tried that and all it does is leave the link…
Vince,
Ah, I think I know what your problem is. The url that you copy and paste between the tags CAN NOT be a hot link. It must only be text. You can paste the link into a new text document and then copy it from the text document as it will drop the hyperlink. Then when you paste it between the tags it should work. I just tried it and it works that way for me. HTH.
Joe Zullo said:
Vince,
I will give that a try when I get home, thanks.
Vincent,
You’re cookin’ now!
test frt. shed.
http://freightsheds.largescalecentral.com/users/noelw/bridge/Tug%20&%20barge.JPG
Nope not working on copy and past or drag and drop?
Not sure how this one worked??? Forgot how I did it after many times doing difference things. gesssssssssss.
Noel,
Take the spaces out of the file name (rename it in your freight shed) that are represented by %20 in the first link and make it look like the bottom one. That should work.
http://freightsheds.largescalecentral.com/users/noelw/bridge/Tug&barge.JPG
