Our Eastern (White) Cedar is very good too, but Western Red is best, but the prices lately are sky high.
We have been using Pressure treated 2x stock for years as roadbed. It doesn’t last forever on the ground, but it lasts very well as benchwork, built just like a deck.
The main difference between building a deck, and building our benchwork, is that we always make our “connections” between the 2x planks, using 18" plates rather than at joists, as is done in deck building. Our joints, using the plates, involve either 6, or 8 deck screws, and the plate is of the same material as the planks.
The plates also act to prevent warping, and make the joints in the roadbed very smooth for track laying.
We do have some PT roadbed that has been on the ground for over 15 years, and is still in good shape. It does seem to help if you use a wood preservative, such as “Pentox” on all cut ends.
We do not put any posts into the ground, instead we use deck blocks, or just patio stones. Most legs are PT 4x4 stock.
When laying the PT roadbed directly on the ground, we do not use any posts or anything driven into the ground for leveling, instead we just use old bricks, stones or anything we want to get rid of, then backfill under the roadbed with 1/2" crushed stone.
Frost is not a problem with this method, as the roadbed floats, and as long as you don’t try going cheap, and stick with the 18" plates (Of the same thickness as the roadbed) and enough deck screws, there will never be a problem with any joints.
John is very correct in pointing out the need to keep the grain “CUP DOWN”…
I would not suggest using tongue and grove stock, for roadbed or decking, as the very nature of the stock leads to warping, due to the thinness and the sealing nature of the tongue and grove joint, which traps moisture. I have known people that have tried to save money by going with Western Red Cedar in 1/2" thickness, and it was found to warp, and split readily in a short time when on a horizontal plane out in the weather. The 2x PT seems to be the best choice at least for us, over the last 20 years and more, in our location in Eastern Ontario, Canada.
Location does cause different problems with materials. Something that works great in the hills of Southern California, may look enticing, but is not recommended for those in more Northern or wetter regions. Frost and temperature swings of over 50 degrees, with rain and snow also cause grief…
Some people in some regions can use the cut and fill (With crushed stone) as their choice, and not have any problems…but when they say they can’t use Kadee “#1 Gauge” couplers on their equipment, because they won’t stay coupled; I wonder what their roadbed looks like…good STABLE roadbed provides more of a chance for FRUSTRATION PROOF outdoor model railroading…so choose wisely which is best for your location.
Before building anything, try seeking out other model pikes near you and look at what they are experiencing, and avoid their problems.
Yes we have also tried concrete roadbed, but found that it tends to be too permanent…just today we had to spend a lot of time removing some of it, that hasn’t been used for years, and due to my late father’s skill in mixing great concrete, it was a “Bitch” to break up, without a jack hammer. A model railroad that is allowed to grow, and changes take place. making the roadbed TOO permanent, is not always an advantage !!
The fact is, that we have probably tried just about every type of roadbed, over the years…so I’m not overlooking what others have tried. We have also found that having the solid wood roadbed has protected the actual track over the years. We do not use screws, and we don’t use the holes in the centre of the plastic ties. We use 3/4" flat head nails, and drill holes on each end of the ties where we are going to attach the track. Don’t drive the nails in too far; leave enough so that you can readily pull them out without damaging the ties. We don’t need expensive rail clamps, as the common rail joiners do the job well. We are of course, all R/C battery…
Use what works best for you…and have fun
Fr.Fred
