HOPPER GATES
I tend to cut most everything from 2mm and 3mm polystyrene sheet and layer parts as needed. My design of the discharge gates required about 5mm (2mm door and four 3mm braces). Rather than glue 96 braces to make up the gates on the 4 cars, I decided to use 5mm PVC instead. A drawback to PVC is that the deeper I cut, the rougher the surface due to the core of the material not being as solid as the outer faces. I’ll prime and maybe sand a bit but not gonna fret about it. In some cases, this can be considered an advantage since the texture can represent rust or concrete.
UNDERFRAME BRACES
To get the end detail I wanted on the cross braces, I printed them in resin
