After seeing Dans engine house with the stone foundation. I decided it was time to replace the current one on the KMRR. It has served its purpose but proved to be too small. The guys had tight space to work in and no heat. I drew up some plans on what i was looking for. My thought was to do a 2 stall house but then decided on a one stall house with a shelter attached to the side to store smaller stuff. I started off by cutting some 1/4 plywood for the main body. The plan is to do stone along the bottom edge and then face the sides with cedar overtop the plywood. The plywood will be re-enforced with braceing on the inside. I chose this method because I have a lot of scrap 1/4 plywood from my shelter project and also because I wanted something with weight and will withstand the weather in these parts. I have had good luck with this method on other structures. I know im no artist.
