After shelving this project last fall and taking the winter off, I am back at it. The current bridge is about to collapse, so this replacement must get installed before disaster strikes. My hold up, as usual, was the details. The vertical edges of the girder plates are simulated with 1/8" Plastruct angle epoxied to the aluminum tube between the polystyrene sheet making up the top and bottom edge of the plates. I had run out of the angle stock and by the time I got them in, my MoJo for this project had left me. The Mojo came back for a short time in late winter and I cut the angle into the 100+ pieces I needed. Then it left again until the rains hit this past week and I needed something to do.
As of today, all 100 verticals have been epoxied to the tube. It’s a slow process as I mix up enough epoxy to glue on 3 or 4 pieces, then start again. I use two spacing jigs made from 3mm PVC to keep things in alignment…
Job finally done…
The simulated break between sections where a support pier will be located…
The next step will be paint which will complete the girder. Rumor has it we might finally have enough weather to paint late Sunday and Monday
