Below are some progress pictures. I’ve been working on the girder, applying styrene to the top and bottom to simulate the angle iron in this area. Also I have been filling the extrusion where I cut back the landing pads. The idea here is to get a flat even surface to sit on the abutment. First the extrusion is filled - 6mm foamed PVC board fits just fine…
Next a layer of 3mm board is epoxied in to bring things up to the level of the cut edges. I didn’t get a picture of that step. Finally, the extrusion is closed with some styrene. As you see, I subscribe to the Bruce Chandler school of clamps…
The end of the tube was also closed off with styrene just for fun. This area really won’t be visible…
I learned quite early to mix the epoxy right on the work piece. Mixing on a card and trying to transfer wasted a lot of epoxy, took more time and was messy. Here is a section where I’m done applying the styrene…
This section was just glued. I use 3mm spacers on both sides to align the styrene and masking tape to hold it in place while the epoxy dries…
A close up of the finished ‘angles’…
I’ve got a couple more feet to go with styrene, then it’s on to attaching the vertical angles. I’ve got enough ABS angle to keep me busy for a day or so, but need to order more.
