I was home from work early Thursday. Temps were in the 70’s with very low humidity. I sat on my butt at the computer instead of getting back to work on this project. Today the temps are rising and so is the humidity - for some reason I was motivated to get to work on the aluminum “girder”. First I used my miter saw to cut the tube to length…
Next, I used the table saw to chop out the landing areas for the abutments on either end…
Once the cutting was complete, I used my ‘DA’ sander with 220 grit to scuff up the aluminum to give some tooth for epoxy and primer. Also shown in this shot is the slice in the center of each side to simulate two bridge sections…
The end cuts were filed smooth and then hit with the DA…
Finally, both ends are ready for some PVC filler to close up the extrusion and create the proper height above the abutment…
I’m going to try and do the next steps indoors as the weather is not going to improve untill late next week, but before I get much further I need to do a test fit on the abutments. I’ll hide in the air conditioning for an hour or so before giving that a try
