OK I decided to start a new thread on this so I can get some fresh eyes on the matter. My yard is being built on a cabinet that will be used for care storage and other stuff. The top of this cabinet is a flat surface 5 feet wide and 10 feet long. I need to make the top completely water tight and even be able to have a certain amount of standing water on it. But it can’t leak down into the cabinet. Several methods have been tossed about and I have reservations about all of them.
The idea I have been holding onto is PVC boards glued together on the edges to form a solid PVC surface. While this sounds great I have some reservations. #1 is cost. I just went to HD and the 1X8X12 (3/4 X 7 1/4 nominal) boards are 45 apiece. I would need 9 of them that’s $405 bucks just for the top. Also I am worried that I still have 8 joints. Am a I sure they won’t crack or separate over time? How much does PVC expand and contract with heat, will this cause issues especially at the joints? That’s a lot of money for an experiment. Plus its bright white and would need something to coat it and make it look nice.
What about pressure treated plywood. I could get away with two sheet at $35 a sheet and would have only two joints to contend with. So that only $75 for the wood. I would have to somehow seal the two joints and then would need to apply a coating on that becuase I doubt even PT ply would be great with standing water on it.
Another thought I had was something very thin say Masonite hard board and then pour a 1" slab of cement on it.
No matter what I do I would need to put some sort of coating on all of these surfaces to help protect them and make them look nice. How are flat roofs made. Could I use some sort of roll on asphalt or ??? and then spread some course sand or fine gravel and have sort of an asphalt roof. What about something like SnoSeal that is rolled onto mobile homes and campers to seal their roofs?
I am open to all suggestions. I need to balance cost, practicality and reliability all in one. I have joists placed 10" on center now for support. I just need a practical water proof flat top.
