I use both track power and Battery RC. At this stage of the game, it would be quite an undertaking to convert all of my existing locomotives to Radio/Battery power, and the railroad was designed with the idea that it would support track power, so we’ll keep using it. On the other hand, I now have some locomotives that are Radio/Battery, and they work quite well also.
Here are my observations about running both, on the same system.
First of all, I should make note of the fact that my railroad is indoors, so that weather is not an issue. The rail is all Nickel Silver, which was expensive, but looks good, and does what I want it to do. So far the only cleaning issues I’ve had involved the avalanche of plaster and debris from above on one section when contractors remodelled the bathroom upstairs. Otherwise, the track powered trains do pretty much as they’re told, and I don’t spend any time cleaning track. If I did, I would be frustrated in a HURRY… I built my last railroad (also indoor) from brass track, and had to clean it constantly even INDOORS. If I build an outdoor component, it’ll be for self contained power locomotives (battery, live steam, etc.) only, as I can’t imagine trying to get that much track electrically clean every time I wanted to run.
Next … while my track powered trains do run, and run, and run, at the moment they can only be controlled from one place. This is because I haven’t got any wiring done for walkaround throttles, and there is only one control location on the railroad. To be sure, the control station is next to the yard, but given the size of the railroad, particularly once the scenery is in place, it’s going to be hard to stop and switch cars, or even run a meet manually without a camera in the engine, or someone on the ground to yell “STOP.” There’s also no provision for controlling the sound system from the control station, so it follows the pre-programmed whistles and bells that a Sierra is set up with. Effective switching or set out, or meets with the track powered equipment is going to require quite a bit of wiring so that an operator can select and control trains in his area from someplace other than the main panel. Again, that’s always been part of the plan… but I wonder sometimes if there might have been a simpler way.
My battery powered, radio controlled trains can of course be run from anywhere in the room. You can follow the train around, or take a post on the stairs and run it from a bird’s eye perspective. You can blow the horn, ring the bell, stop, start, reverse with little regard to what anything else on the railroad is doing, beyond, of course, avoiding a collision. The avalanche, the temporary power interruption caused by installing two “dead frog” switches in the mainline, the tracks in the yard that I haven’t had time to hook up yet… all no problem for the Battery equipment. Of course, you do have to charge it, but then I’ve not run into a situation yet where I wanted to run something and nothing was on charge. And… if it were, there’s always the track powered stuff.
I want to include some automation of the railroad. While this flies in the face of all the advantages of walkaround direct “in cab” control (which is a trademark, I understand…) of trains, on the days that I want to run the railroad as a whole (due to lack of other operators, or simply a desire to switch hats and be a railfan) it will be nice to have trains that can respond to signals, or be “programmed” to do various things at various places. My knowledge of DC wiring will lend itself nicely to having my track powered trains do this… and when my wife decides to have her 3rd graders over for a special event, or folks drop by who don’t necessarily WANT to be an engineer, it will allow me to run a couple of trains at once without worrying about a disaster of Addams Family proportions. The Radio/Battery stuff would be harder to do this with (though not impossible) and this kind of operation really doesn’t use what Battery / RC does best.
So … I think I have the best of both worlds. I can run on automatic, or operate from as close to in the cab as one can get. I have all kinds of flexibility in the combinations of the two, and I have one to back up the other. Guests can bring track powered stuff OR battery equipment, or, I suppose, even live steam (though coal indoors…no!) and they’ll be able to run.
That said …
If I had it to do all over again, from the day I bought the Shay, and didn’t have anything else large scale except an old LGB starter set from 1983 … I think I’d go radio/battery. Certainly it’d take awhile longer to build up the roster, as each locomotive would have to be equipped with the power system, but I could run Aluminum track, and skip the wiring, and buying the power supplies, building the control panels, etc. I could get on to the railroading right away, instead of spending all the time I’ve spent doing power and wiring, and would never have to worry about blocks, short circuits, or isolating trains from each other. I know when the Bachmann K arrives, it’ll be battery R/C because I want to be able to make it do everything its 1:1 sister does, and I want to run it, personally. I have another potential R/C locomotive in the pipe as well… I’m sold on the idea. Does it mean I’ll never have another track powered one? No … since I do have the capability, some locomotives will be track powered, and will be very useful that way. But if you can get in early on the R/C battery side, do… particularly if you’re operations minded, and prefer your trains at the engineer level instead of the superintendant level (both of which have their merits.)
There’s no war involved, or needed. It’s really more a function of what you want your trains to do, and how to best accomplish it. I’m lucky in that on my railroad there’s more than one possibility.
Matthew (OV)
