I wanted a engine tote for my EBT #12, but I also wanted to be able to use the same case (or part of it) as an engine cradle. The pictures are fairly self explanatory, but I’ll give it’s operation a run down. To open things the latches on each end need to be undone.
Next one of the sides can be pulled out and then the other. At this point the top is now free from the T-bolts and can be lifted off.
If you want to use the top as a cradle just re-latch the catches on the back end of the top. I still need to ad the foam padding to the top. The bottom won’t get any.
