I bought a used 28192 Mogul on Ebay, the seller said “This attractive locomotive features operating headlight, operating smoke and operating sound Piece worked when bench tested.”. I was able to put it on the track last night for the first time with power and found neither light worked and I cannot get the smoke to work. The firebox light works but since the lights and I think the smoke are active based on direction of travel I figured it must have something to do with the controller in the engine knowing that the engine is moving and which direction.
There is a three position switch on the engine, I believe it to be Off, Lights and Smoke, Motor Lights and Smoke. The Sound switch is in the Tender.
I am using LGB DCC.
Any thoughts on what I should be looking for?
