I started another thread asking about R/C for my davenport. I figured that out so now I figured I would share my adventure in modifying my Davenport.
I’m waiting on parts to come in so I figured I would start on couplers. The standard 830 doesn’t fit and you can’t do the normal Bachmann link and pin pocket conversion like you can the shay or climax.
So, I started with a Kadee 904. I trimmed the end off so it wold fit in the draft gear box. I also remove the trip pin from my kadees. The Brass eye pin was put in by accident, the bachmann coupler lever chain has a pin on it.
Next I drill and tap a hole for 2/56 threads. i use the kadee flat head screws and just cut the head off. I then used CA glue and attached spare coupler springs over the screw. I also drill an 0-80 clearance hole in the shaft of the coupler.
To mount the coupler I trimmed off the fake pin and drilled and tapped a hole for an 0-80 bolt. The bolt goes through the clearance hole I drilled.
This is what it looks like underneath before the draft box is covered
More to come…
Terry
edited because i can’t spell
