I heard rooster feathers work well for cleaning. I know were you can find some.
I hope you are able to resolve this problem, but I also want to see a boiler shell and cab launched into space. With a little work it might be possible to make a locomotive rocket that would actually fly well and be recoverable
Jon Radder said:The cab looks nice. It wouldn't be making the journey ;) Besides, more Aero without it. I like easy :D Ralph
I hope you are able to resolve this problem, but I also want to see a boiler shell and cab launched into space. With a little work it might be possible to make a locomotive rocket that would actually fly well and be recoverable :D :D :D
Ralph Berg said:1. A couple E9-8's and they'll be watching it zip past the ISS !
If that don't work I'm going to tape some Estes rockets to it and send it into space
- Man, just think of all the UFO reports that would cause - heheheheheheheheh . . .
Ric Golding said:True. It's still deeply frustrating when the goal is spiffed up varnish power to show your customers how good and well taken car of a company they are doing business with.
I sure do think that looks good, well kept but slightly weathered. Don't beat up on yourself so bad. There is a lot of us that would like to do that good of work.
Ralph,
I’m going to stick my neck out here only because nothing seems to be working for you. I have been using Bondo Primer for several years now. I’ve put it over various paints and on almost every kind of surface I can think of. Bondo primer comes in three colors; ruddy red, grey and black.
After washing off whatever cleaning agents you might use and allowing to dry why don’t you try the Bondo grey primer just in case? I almost never advocate any particular brand, only report my own experiences with them, but in this case why not take a chance? It can’t be any worse than your experiences so far and might work, hopefully as well for you as it has for me.
Disclaimer: My apologies in advance if it doesn’t work. hehehe!
Do you use Krylon and Rustoleum over it? I use both Rustoleum and Krylon and I know there are times that would really be handy.
Richard,
I’ve been keeping an eye out for the Bondo Primer. I recall you saying you’ve had good results.
Doug,
I use Rust OLeum over Krylon Fusion. Also over Krylon Black. Usually don’t have any problems.
The tender was RO over Krylon Gloss Black and turned out fine.
