Tim Brien said:
I have done many bashes on the taper boiler of the Anniversary and they all finish up with that typical narrow-gauge look. There is not enough 'beef' in the bulk of the body to make a believeable standard gauge loco, apart from a complete rebuild.
I'm not going to argue matters of opinion, especially given Tim's experience with kitbashing Bachmann 4-6-0s. Suffice to say I don't agree with his assessment. In comparing my 4-6-0 to the drawings and photos of the Ma & Pa loco, it's a very doable conversion. The major dimensions are all within scale inches. You'd obviously want to replace the boiler fittings (headlight, air pump, etc) with smaller-scaled details. The hardest thing would be replacing the domes, but that's not a difficult task. The stock sand dome would work nicely as the new steam dome, and Trackside Details makes a sand dome which is almost perfect to replace the sand dome. The only "major" discrepancy is that the B'mann firebox is about 1/2" too wide, but that's hardly a deal breaker. You've still got plenty of leeway to build a proper 4" wide cab (9' 6" per the prototype) and still have room for cab doors. The tender need only be narrowed and shortened--hardly insurmountable steps for even a novice modeler.
Tim Brien said:
If it was a relatively simple operation then there would be examples in abundance, as modellors are constantly crying out for standard-gauge prototype models.
That argument assumes that modelers who cry out for a model would build one even if it were simple. I don't see that as being the case, at least not in general. Take a narrow gauge inside frame 2-8-0 as an example. The various fora are full of pleas for Bachmann (or whoever) to make one. Barry's Big Trains has had a 2-8-0 drop-in replacement frame for the Bachmann 4-6-0 for years. A few simple turns of the screw, and anyone could have a VERY reliable 2-8-0 running on their railroad. Not many people do. I could easily use one myself, but I've yet to order one.
When you look at raw measurements, many of our narrow-gauge prototype locos can be rescaled to standard gauge without too much difficulty. The catch is that the lion’s share of people in this hobby are “10-foot” modelers, so the scale discrepancy between a 1:22.5 locomotive pulling a 1:29 box car doesn’t bother them enough to break out the hacksaw. That–more than anything–is why I don’t think we see more examples of “downsized” standard gauge locos. It’s easier to accept the size compromise, or–if that’s unacceptable–to simply do without and run what is available in our chosen scale, waiting (and waiting) for someone to make what we want.
