There used to be a railroad here! an engine house to be exact.
the engine house has been removed:
the plan: the new roundhouse will be in the crawlspace.
the three existing yard tracks get extended as well. An approximately 32 high x 7’-2" opening in the concrete wall.
the old engine house is potentially available. because it was up on a bench at eye height, the far side roof and walls were not covered in corrugated tin, and some floor boards are loose because the screws holding the structure down were under those. PM any interest.
so this was phase two of the project, to open up the crawlspace to remove earth behind. I had bought on eBay a 16" concrete saw, and before it arrived saw a bad review on YouTube, so was skeptical of success, and finally got up the courage to give it a try. it works fine 1" at a time, i did try 2" but it didn’t like it and tripped out the breaker.
as you can see i have had success with phase two, opening up the entrance to the crawlspace just below bench work height.
next comes further earth removal.
AL P.
