Update:
Much planking:
The small gaps you see are intentional. I plan to extend the roof a bit to cover the loading dock, gluing the “roof beams” directly to the loader roof. Then I’ll plank over the rest of the foam. In the meantime, I can glue metal sheets along the narrow strip between the loader and mill, finishing both sides, and prepping to metal over the roof. Naturally, my other green bottle of DAB 3.0 whatever was NOT, in fact, the gutter sealant, so a hardware store run is again in order. Whatever the heck it was (some sort of self-leveling crack sealang), it ran like thin pancake butter…but it did glue the loader shed roof to the foam! Read the label next time, Mueller…
I used scraps from my father-in-law’s donation to make a beam that ran lengthwise along the mill, resting on the window sills. Using Bill Barnwell’s idea, I ran copper tape along each side, soldered some LED-s to it, ran the wire into the shed, soldered it to copper tape on the shed roof, and wired the lot to a battery clip. Before you ask, yes, I did do this before gluing on the roof! Results are below:
Not exactly material condition DOG ZEBRA or even CIRCLE YOKE for that matter…I am thinking of finding some dark cloth or plastic and hang it as a black-out curtain to the inside of the mill’s roof to keep light from leaking. Errors of cutting and placement early in the project have come back to haunt me. Were I to do this roof over, I would’ve carved a groove in the inside face of the foam for the roof material to rest in. Lesson learned…
Overall, though, I am excited to be over the hump. With the roofs in place, I removed all the material I had been storing in the mill’s interior and - GASP! - even started putting some away! There is still a month of building, fixing, painting, etc. ahead of me, but this project has psychologically moved into the “finishing” vice “building” phase.
Updates as required!
