Aloha,
OK, we are moving from ideating to doing on this one (see A Question of Basics – Techniques for Large, Simple Structures). In brief, the idea is to convert my pink foam into a reasonable facsimile of a the sugar mills on O’ahu. From my photographic research, these were large, had a huge stack for the power plant, a covered areas to unload cane, and tracks to store the empties. For my purposes, this is to serve as an “anchor project” to set aside that lobe of the layout as the place where the Triple O (our analog to the OR&L) picks up sugar from the M&K Sugar Co. (initials are from my last name and CINCHOUSE’s maiden name). In time, I plan to fill this area out with the outbuildings for the plantation (engine service area, workshops, whatever). For now, the mill has to say “Hey! That’s a sugar mill!” as part of the long range effort to better anchor the Triple O in time and place.
I have learned at long last to start with a a mock-up. The material, in this case old boxes, is free. Yesterday, Youngest Daughter helped me to cut up the boxes, and we got about as far as the unloading shed:
We ran out of material, I tried to be lazy and tape together a frame, and, well, no…
Today, while the 1:1 crew was involved in their homeschooling, I scrounged more boxes and proceeded to cut. I moved it all out on the railroad to get a sense of size, staging the 1:24 crew to help me see this in proportion (and because I enjoy staging these guys!). The first shot is the primary viewing angle:
From front to back you see a passing siding on the mainline, the M&K’s engine service track, the M&K’s empties track, and the can unloading track. Again, there is simply no room to do much with the track, so the cane trains will have to pull their loads into the mill and out the other side.
The next shot would be visible from our lanai. I placed the shipping box there to break out the outline a bit. I thought it could serve as an entrance or connected outbuilding.
I might add a ventilation “shed” (not sure of the word here; in the pictures it looks like a little house on top of the structure) on top of that roof, too for similar reasons.
The next shot is the “back.” I figure this could be where I put the molasses tank (represented by the cookie tine) or fuel dump for the power plant (The Triple O runs on coal).
The overhead shot really showed me how big this thing will be:
My first thought was, “That’s a lot of surface area to cover with crimped aluminum from salvaged beverage cans!” I am going to have to weigh going commercial on the siding Financially it’d probably be a wash, though I am sure buying the siding will be better for my health and ultimately less frustrating. I am thinking that a plastic siding will also facilitate the addition of plastic pipes, vents, rails, etc. as the mill and complex evolve. My second thought was more aesthetic. Is this too big? Does it “over dominate?” Need to think on that!
More fitting and fiddling to come before we start cutting the foam.
