Update:
I actually made some progress! I was going to start to cut the base for my roof, but something wasn’t quite right…It turned out, I had not centered the peak and, to make things worse, mounted the two end walls such that the peaks did not even align!
Measure 57 times, cut once, and screw it up anyway… I called for OD (some good from this remote schooling stuff!), and we worked together to use a hotknife to cut off the peak at the left. We have found that the knife bends pretty easily, so she worked the handle while I pushed the blade gently on the other side. Off it came, a couple of skewer bits and some glue later, and all was well.
Today, there was progress on multiple fronts. Kid-zilla and I caulked up all the seams. I am sure this is unnecessary, but it seems like a good idea to me n terms of weatherproofing.
He then assisted me in taking some of the curl out of our beverage cans. We ran them back and forth over his table until the were OK:
I did try to get him to wear gloves. He refused, and I guess we got lucky. I’ll start annealing the metal in the oven over the next several days as CINCHOUSE permits. Yes, this is tedious…
For reasons I no longer remember, I had resolved upon making the loading deck from plastic sheet. We have a shattered sheet of plexiglass we’ve been slowly cutting up for projects, and one shard was a near perfect fit. After shaping it, I followed Ancient Wisdom, scribed it, stressed it with and old saw, painted it, and gave it a wash. The result, prior to some clear flat paint, is below next to my usual tools of the trade:
Never mind that some of those lines are only parallel in a non-Euclidean sense, I thought it looked pretty good. OD even asked, “Where’d you get that?” Score one for me! I know this is not a new technique, but I had never used it before. OD suggested we actually make the rest of the loading shed in a similar way. Since we have to make doors and stuff, why not? The irregular shards of this plastic are insufficient for the job - and I’ve no idea what glue will work or desire to experiment - but sheet styrene is available locally. May as well reinforce success.
The last bit of work today involved sketching on the windows. Naturally, as the picture shows, I loused this up:
I’ll cut out the holes and fit the egg crate (Thanks for the suggestion, Bill!) during the next surge. While not authentic to any mills of which I am aware, this style and placement is similar to the contemporaneous buildings still standing in Pearl Harbor Naval Shipyard, making it authentic to time and place. The black areas is where can would be offloaded onto a conveyor and hauled into the building. OD didn’t think trying to cut a depression in the wall to increase the illusion would be worth the effort. Then she said something to the effect of, “Of course, if this were my project, I’d have build a detailed conveyor! But, you know, this one is yours, Dad.” Smart aleck.
I’ve some MOW work and loco maintenance on my “to do” list, but the project is beginning to resolve into bite sized sub-elements of things I can do with 10-20 minutes here and there. Oh, and we are back on a “stay-at-home” order. Darn the luck…
Updates as warranted, and, GAP, thanks again for the tip on the adhesive!
