I recently received a FA-1 from an ebay auction. It seems to run okay but has a good bit of pulsing and wobbling almost like something’s out of balance. It did not come with an info so I’m not sure how to crack it open and lube the engine.
I lubed the axle points outside the block but there must be other places to lube. There are 4 small Phillips screws on the bottom of the block that I guess may get me to a gear box but my jeweler’s screw drivers won’t turn the screws. I’ve got it running about 1/3 throttle on rollers now and it’s smoothing out a bit. It’s much worse in reverse than in forward.
I would welcome advise on how to lube and troubleshoot this issue.
Thanks,
Scott
