Kyle, I did notice the wheels seem a little bit wobbly but not too bad. I will try and check gauge and adjust any that seem too far out of true and see if that makes any improvement. The gears all seem okay with no visible cracks.
I noticed that even laying on it’s back in my foam ‘cradle’ that this rhythmic wa-wa at low current is present with no resistance to the wheels. I took the cover off of one motorblock at a time which left only the rear gearbox in place, the one that runs off of the U joint and applied power and it still seems like the rhythm sound is still there but less pronounced. Then I’d place the cover and front axle back on the block without screwing it together and re-energize and it would be slightly more noticeable each time I went from running one motorblock, to running one and a half motorblocks to running both assembled blocks. It’s almost like there’s a flat spot or something in one or both of the electric motors [?] sure is puzzling and I just can’t track it down.
This is why I’m considering searching for some new [or newer] ART29351 replacement motorblocks and modifying this early FA-1. For the price of two new motorblocks though it may also be just as easy/cheap to search out a bargain FA-1 in any paint scheme that is running well and swap the old body on to a newer frame. No rush on this project so I have time to consider different solutions. Thanks for the tips on adjusting the wheels.
