OK so Bruce’s fire house build and the question of lighting came up. I had not given much though to how I am going to light the buildings on my layout. I know I do as I think it would be fun for night ops to have everything lit.
So are the ways people are running a feeder wire throughout the layout. On the bench sections it is a no brainer but what about on the elevated dirt portion. It seems to me that running a feeder everywhere the ladder goes would be logical. That away it is easy to get to and available throughout the layout. Do you use a conduit and if so what and how do you splice into it when you decide where a building will go? Direct bury if so what wire do you use? What size wire should be used as a feeder? 12v to run a single LED or a group of LEDs in series at a specific spot with all of the sub groupings and single LEDs run parallel?
What are folks doing?
