LED’s are pretty much a no brainer, I use 3mm and 5mm LED’s on just about every thing on my RR where I want light, including the engines and passenger cars. I use both Bright White and Soft White LED’s, this depends on where I use them, mainly Bright White for engine headlamps, etc. and Soft White for everything else in most cases. I buy the 12v 20 packs on eBay for around $10/12 dollars and they come with a resistor, plus I add 100 ohm resistors when I want the light a less brightness then what it light up on 12v’s. All my passenger cars, or cars with lighting I run a 9v battery for 3/5 LED’s and as of now I have yet to replace a battery on any of my cars. Using different resistors for light brightness is pretty easy to do, just try different ohm resistors and when the light is to your liking your ready to solder the wires together. You can use all those figures that some have talked about, but what a lot of figuring when not needed, just look at the power voltage, the LED rated power needed, and resistors to control your light brightness. The worst thing that can happen is you overpower your LED and it burns out, I burn my LED’s some times for hours just to make sure my power from my supply will handle the LED and the correct number of resistors. This is just not Rocket Science, more commonsense then anything else.
